Rev 4 vs Hydromotive vs maximus
Re: Rev 4 vs Hydromotive vs maximus
Originally Posted by Payton
My point was that with a 23*V and and a very light hull. 200 more HP could equal 10mph. I think he has more pitch on his prop now. The bow feels light because it is light. He's running like a bass boat.
Gear ratio is 1:1.36 props might have been labbed not sure.
boattest report for info athttp://www.campionboats.com/downloads/Chase%20910%20I%20SC%20-%20TWIN%20496%20MAG%20HO%20MPI%20Merc%20Bravo%201. pdf
If I replace the 2 Rev 23's with a hydromotive what pitch is comparable?
(damaged one prop)
Regards
Rick
(damaged one prop)
Regards
Rick
I've spent a lot of time in same boat but one engine.
These are lightweight (for size) and have a pretty flat bottom.
Rough water ? It does not like rough water at all. Use trim, trim tabs, and keep speeds down and it will make it but with a lot of banging around.
I actually like it since it does air out so well, however, it comes at a penalty - rough water.
.If I replace the 2 Rev 23's with a hydromotive what pitch is comparable?
(damaged one prop)
Regards
Rick
(damaged one prop)
Regards
Rick
