real or fake 496 HO ??
Re: real or fake 496 HO ??
though the longblock assy is probably the same.....the dress is completley different, i see a crank driven seawater pump ......looks like old volvo stuff....
Originally Posted by evaluex
I thought Marinepower uses from 2006 the MEFI 5 ECU
Dave
This is from the FAQ page on their web sight:
"What's the difference between Mercury and Marine Power Engines?
Both Mercury and Marine Power purchase their major raw materials and components from General Motors. Items such as base engines and EFI electronics are similar in all name brand engine manufacturers. The only real difference is marketing and packaging. "
No way you can comparise a MEFI 4 (batch fuel injection) to the PCM 555 (sequential fuel injection) ...
Thx for the different replys
Can someone confirm that this engine is still equipped with the MEFI 4 system (not the MEFI 5) . Better HR pictures are included
Does Merc uses the same GM camshaft or are they replaced by their own brands ? Someone has specs for the Merc 496 HO ??
The Merc 496HO and the MarinePower 425HP 496 both use the GM powertrain HP-2 marine base engine. The differences come from the different marine accessories both use. The marine power uses a different closed cooling system and it uses the MEFI4B ECM which is batch fire. The Mercury 496Ho uses the PCM555 ECM which is sequential fire and it has more protection and engine histororical data in the Guardian system. Both motors should make about the same HP and torque and run about the same. Here its now clearly a cost benefit analysis comparison from that point on. If your freind can receive good warranty service and the motor performs as expected then it will be up to him to decide if the approx. $7000 savings is a good cost benifit. From what you are saying it does not seem as though the seller tried to deceive him on the purchase.
Ray @ Raylar
Ray @ Raylar
Thx Ray..finally the answer from the 496 "doctor" I was waiting for
Regards from out of Belgium and Alfred (496power.de)
