Max Rpm
![Question](/forums/images/icons/icon5.gif)
What Is The Max Rpm For A 91 454? No Lonhger Stock
Here Is What I Have
Srp L2399f Pistons 10:1
Arp Rod Bolts
Crank Is Original And Has Been Fluxed And Polished
Aluminum Heads
Retro Fit Lifters
Crane Roller Rockers 1.8
750 Holley
502 Intake
Gm High Perf Ignition
The Only Parts That Are Original Are The Block And Crank. Everything Else Has Zero Hours.
I Have Been Told Every Thing From 5000 To 5500
What Is Safe?
Here Is What I Have
Arp Rod Bolts
Aluminum Heads
Retro Fit Lifters
750 Holley
502 Intake
What Is Safe?
Originally Posted by the duke
ARP rods??? I assume you mean ARP rod BOLTS.
Was this a Magnum engine?
If it was a Magnum, you can turn 5500 with no issues.
Registered User
Originally Posted by BY U BOY
YES ARP ROD BOLTS AND NO IT WAS A 7.4L 330.
I'd have no problem with rotating assembly if machined / installed / balanced correctly.
Valvetrain is the # limiter with RPM - especially with hyd roller pieces.
We'd have to know what your are running for valves, retainers, springs, rocker arms, etc, etc especially what the installed (on your motor) spring closed and open psi's are.
I AM NOT SUR OF THE SPEC BUT THE CASTING NUMBER IS 12363391 THEY CAME FULLY ASS. AS FOR PSI I DON'T KNOW
I would not run that engine over 4600 with a Cast crank. I had a modified engine with a cast crank and I broke it in 2 pieces. Forged crank is the only way to go. Just my 2 cents.
MY HEADS ARE GM PERFORMANCE ALUMINUM OVAL PORT
Even if they came with a spec, you need to find out. This goes with any cyl head from any manufacturer.
Without knowing this means you do not have any idea where the valvetrain will bounce and bust you up.
Therefore, no one can answer your 'where's my rpm limit' question. Not being a dick, but we just can't.
