Gaffrig Shifter Setup
I am installing a Gaffrig throttle control and shifter in the Boat.I want to know which of the three locations for the shift cable I should use for a Bravo 1.I called Livorsi today and after an hour on hold ,all I could get is that I will have to determine it myself.I would think that Bravo 1 drive would require a given amount of travel to shift it.
I usually start with the far outside ones also. This assures full travel into gear. The only reason you might have to change is if the shift/throttle doesn't move back and forth enough from center, but I have not run into that on Merc products.
SHAKEN Not Stirred
29
06-26-2003 01:05 PM
timucin
10-22-2002 09:01 AM
