will hp500 valve cover fit on merlin heads?
Charter Member #737
Re: will hp500 valve cover fit on merlin heads?
Originally Posted by 98itrwhite
so they wont fit merlin cast heads?
Originally Posted by KCHOTBOAT
Mine did not. The exhaust valves and exhaust ports where set up higher on my Merlin Heads than a stock GM head. I had to use tall valve covers to clear the rockers. This was a gen 6 setup if that matters and I did grind off all the oil drips before I tried to use the valve covers.
Different heads have different height valve cover rails. You'll really notice this on small block heads. As a heads up.
