Adjusting lifters 1/2 3/4 maybe more? >
Old 08-24-2006, 11:34 AM
SB
Received 3,277 Likes on 1,467 Posts
Default Re: Adjusting lifters 1/2 3/4 maybe more?
Originally Posted by Wobble
It can get messy, but if you are able to run motor without valve cover on, you can take a balled up rag and cover each lifter in turn to see if it's just one or all of them taking turns.
I personally have had no luck this way. They always seem to tick even when you get to the point they are tightened down too far and the engine runs like crap.
Adjust the rocker arms the normal + correct way (two different methods - either is fine) and then move on to diagnosing other parts if you think this noise is still a problem.
Unfortunately noise issue diagnosing over a computer is near impossible - hard enough when looking at it live. So I can only give input which in no means may relate to your situation. Sorry.
SB is offline
Old 08-24-2006, 01:56 PM
Called crane tech line. Thye said they like one full turn and no more than 1.5 on a BBC. I will give that a shot.
BadDog is offline
Old 08-24-2006, 08:00 PM
OK, adjusted to 1 1/8 and they are good now.
BadDog is offline
David Stotz
3
06-16-2007 02:52 PM
NOMOGOFAST
0
07-19-2006 06:10 PM
JON242
2
06-12-2003 04:47 PM
Cord
12
09-20-2002 09:32 AM
Bo Knows
04-02-2002 09:20 AM
Quick Reply: Adjusting lifters 1/2 3/4 maybe more?
