Lost 10 mph.Help
Re: Lost 10 mph.Help
Sorry to see you are going through all this chit Rich...just seems to be the case around boats for most people
It's probably some meaningless little issue that you will eventually find. I would keep pestering the bravo shop about the drives. If they won't help you at all I would "let everyone know" how great their customer support is/isn't
Good luck. If you just need a weekend of drinks and no worries...you know where Murray is. y'all are always welcome. We will even have some MOHETA's waiting
AKA NoMoBoatin
Don't think i need to tell anymore about the service they give.
You will lose several mph when going from the 1.5 to the 1.3 ratio. If you test with XR's at 1.35 ratio you will see a big speed difference.
There is nothing you can do about it. It's simply a matter of friction. I wish Dean would redesign the upper gears to give us a 1.5 ratio. He says it's not cost effective for him to have the gears made at this point.
I would figure 4-6 depending on power.Mine was 6 Also I was told that on a bravo one 4 blade prop the 30 pitch was the most efficient pitch ,that anything above was not as efficient.So the TQ multiple's might out weigh the prop efficiency? Might? I know on my Scarab the 1.50 was faster. also Joe at Hustler said on the 388 that the 1.50 was faster that a 1.36 in stock form 500efi's.
rob
Originally Posted by Strip Poker 388
How many prop sizes would you have to go up with the 1.5?
rob
rob
AKA NoMoBoatin
Dean just emailed me and said he is sending me 2 new lowers that should make it for the speed lose.Should have them next week.I'll post the outcome when i get testing done.
What lowers did you have verses what he's sending?
AKA NoMoBoatin
Same ratio?
Originally Posted by Back4More
He's most likely sending you the -2 lowers.
