How To Bypass Omc Shift Assist???????
I've Herd About Bypassing The Omc Shift Assist But Don't Know How. Will This Work With An Hei Distributor??
Toxic FORMULA
You can't bypass it and still have it shift properly. I converted my point distributor to electronic which required a bypass circuit for that. It protected the electronics from the shift interupter. It didn't bypass the interupter. Could this be what you're after?
You can hook it up like a Mercruiser. The wires out of the switch go to a plug. Pull them out connect one to ground and the other to the - side of the coil. When you shift it will kill the engine for a microsecond to allow it to come out of gear. This works good, I've done it several times.
fund razor
6
05-21-2004 09:57 PM
