Always friggin' something!
Took the boat out today for the first time this year (long story). Ran great, but had a problem with the trim on one drive. The port drive would lower with trim switch, but no raise. Would go up fine if I used the trailer button, so the mechanicals are OK. I'm thinking it's a bad switch/wiring. Any thoughts? Might be a good time to add trim on the throttle - been planning to do that anyway.
Always something! This sport is worse than drinkin'
Test/check your trim harness connections at the pump.
You can ohm out the trim switch to insure that it is functioning.
It could be a loose or faulty connection.
Originally Posted by dockrocker
The port drive would lower with trim switch, but no raise. Would go up fine if I used the trailer button, ![Big Grin](/forums/images/smilies/biggrin.gif)
Originally Posted by cuda
The worse thing for a boat is to let it sit.
artselectricinc.com
Originally Posted by SB
Typically (I did say typically - not 100%) trim limit switch on drive. Very common.
Have someone hold the switch while you "tap" the appropriate trim solenoid. Probably just got a bit sticky from non-use. This happens rather frequently here, but the wife and I ARE getting along in years. --- Jer
