How much oil is ok for a 502mag >
Old 09-10-2006, 04:13 PM
Default How much oil is ok for a 502mag
I have heard from several different people that the 502 mag burns a little oil. I ran mine about 45 hours this season, maybe 5 at wot. That is being generous. I put about a gallon of oil in this motor over these hours and was wondering if that sounded right to anyone. Any information would be appreciated. This seems to be a little much.
BTW the boat has ran excellent all year. Never a problem..
Coryj
coryj is offline
Old 09-10-2006, 04:18 PM
Downtown42's Avatar
Default Re: How much oil is ok for a 502mag
Merc manual states 1qt every 1-5hrs running time. You are fine.
Downtown42 is offline
Old 09-10-2006, 05:30 PM
21 and 42 footers
t500hps's Avatar
I had to add a qt every 5-10.....
t500hps is offline
Old 09-10-2006, 06:19 PM
Toxic FORMULA
mopower's Avatar
My 540s use about a quart every 10 hours and I'm fine with that
mopower is offline
Old 09-10-2006, 08:39 PM
I have the same issue with my 502 mag. Every couple of weekends I would add a qt of oil. A freind suggested using mobil 1 syntheitc, so yesterday I changed the oil to mobil 1. I noticed a 5 lbs increase in oil presure after warm-up.
I won't know for a few more weeks if it will help with consumption, but the higherr oil presure leads me to think it will.
cstobe is offline
Old 09-11-2006, 06:09 AM
SB
Received 3,209 Likes on 1,453 Posts
These motors come with low tension oil rings. It's the nature of the beast - oil consumption that is.
Alway check your oil level and add if needed.
BTW: this is not an issue. The only 'issue' is if you let it go low enough to cause issues.
SB is offline
Old 09-11-2006, 08:13 AM
Ted G's Avatar
I use only M1 synthetic in mine and it is great for oil pressure, but you will still use oil-about 1 quart every 5 or so in mine at 3500 to 4000 rpm cruise.
www.cbpba.com
Ted G is offline
Old 09-11-2006, 11:06 AM
articfriends's Avatar
SB is right,low tension metric rings on the stock j/e pistons,these things used oil from day one,Smitty
articfriends is offline
Old 09-11-2006, 03:36 PM
Thanks alot guys. I'll watch the levels and keep on going
coryj is offline
Old 09-11-2006, 04:04 PM
SeaRay Jim's Avatar
IN it's first season and about 45 hours, my 540 used about 1 qt every 5-10 hours also. This season I'm running Amsoil 20w-50 (SRO) and it's not really using any.
And like Insptech, my OP is better. I was running Valvoline 50wt racing and OP would be really high at first but drop as it got warm, then take a long time to recover. Not real stable, especialy when running hard either. With the Amsoil it's much more stable. It's not as high at first but stays consistant and even after a hard run, it will only drop 10 psi or so and doesn't take long to recover.
SeaRay Jim is offline
Quick Reply: How much oil is ok for a 502mag
