502 MPI - ASM lower intake versus stock
Does anybody have conclusive evidence on whether or not the Arizona Speed and Marine lower intake with the hogged out ports and cut down runners makes more horsepower and has better upper RPM breathing than the stock Mecruiser upper intake that is used on the 502 Mag MPI?
It was proven on the dyno 10 years ago in hot boat magazine but along with the top end hp gain over 5200 there was a drop in midrange tq from it too. It took a modified throttle body,bigger cam and some head porting to see a substantial gain too,Smitty
Smitty,
I've been real curious to know whether the lower intake is the 5200 RPM wall or if it is the throttlebody for N/A. We've all seen the pictures a thousand times but I've attached photos of the stock intake, Lingenfelter ported and ASM ported. I was suprised to see how lightly Lingenfelter ported them versus ASM and the picture of the red manifold is from a 540 CI Lingenfelter engine. Since Lingenfelter helped design the manifold, you would think he would hog it big time if he knew it made power. Just curious and don't want to leave horsepower on the table.
I have an ASM 500 EFI intake with oval ports and large throttle body for sale if anyone is interested. It was going to be for my 572 NA engine, but I decided to build a 540 with an M-3 like Smitty!!
Send inquiries to:
[email protected]
Send inquiries to:
[email protected]
Originally Posted by BGIII
Smitty,
I did make over 900hp blowing thru a STOCK 502 throttle body and upper plenum with my home ported lower intake and home brewed fuel rail system but thats not apples to apples with this discussion. A buddy built a 540 with a early 502 vst mpi intake that has runners cut down to plenum and crappy edelbrock heads with tiny isky cam,it won't pull a 26 pitch merc prop past 4800 in a 22 ft scarab but its such a ill thought out package I can't put all the blame on the intake sytem. I did have my stock throttle body flowed and it flowed around 600 cfm but throttle bodys are rated different than the way I had it flowed so thats irrelevent too. I bought a spare throttle body this spring,as soon as CFM/scott gets me scheduled I plan on having it ported. If I freshen my motor this winter and can find a spare mefi3 I am going to get it programmed while on the dyno without the blower hooked up and see what my motor makes N/A,with a stock and higher flowing throttle body,it will put this question to rest,Smitty
Originally Posted by cobra marty
Did you extrude hone the manifold?
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
articfriends what size is your motor also are you running a solid roller and what boost.
![Drink](/forums/images/smilies/drink.gif)
