502 cam specs please
Location: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
1 Post
I am rebuilding my port engine of my 502 carbed 415hp Tmercs and was wondering if anyone has the specs to the oem mercruiser camshaft. Would anyone have a crane part number equivalant or suggestion?
engine in question is serial number 0f077723
trying to match oem stb engine(07077715) and get the boat back in the water to finish up the season
Many Thanks
gociggie
Many Thanks
gociggie
Go to Bam's site www.mercruiserparts.com , go to engine look up tables, find your engine and it's camshaft part # and then look below. Disclaimer: these are my notes from other sources and being human I am wrong sometimes.
Mag BBC 454/502 Flat Tappet (rect heads)
.004” 296*, 296*
.006” 286*, 286*
.050” 224*, 224*
.200” 130*, 130*
Valve lift with 1.7 .510”, .510”
LSA 115.5
Merc Part#431-9830 / GM#14096209
ICL 114 ATDC
ECL 117 BTDC
GM Part#10185060 (same as above but ground with 5 degrees advance)
ICL 109 ATDC
ECL 122 BTDC
Merc Mag Roller
Merc# 431-850478 / GM#12551622
.004 300*/ 300*
.006 288*/288*
.050” 225*/225*
.200” 125*/125*
Lift .483”/. 483”
ICL 109*
LSA 115.5*
.004” 296*, 296*
.006” 286*, 286*
.050” 224*, 224*
.200” 130*, 130*
LSA 115.5
ICL 114 ATDC
ECL 117 BTDC
ICL 109 ATDC
ECL 122 BTDC
Merc Mag Roller
.004 300*/ 300*
.006 288*/288*
.050” 225*/225*
.200” 125*/125*
Lift .483”/. 483”
ICL 109*
LSA 115.5*
1 Post
