Found Copper & Silver metal in oil filter...
Re: Found Copper & Silver metal in oil filter...
Originally Posted by Blue by You
I did replace the stock cams with crane 731's in the copper color (ordered it myself) If a lifter or spring came apart and started tearing into the cam... I'd for sure hear something wouldn't I?
Nordic95
FIERCE ALLEGIANCE
I'm not sure of anything... I didn't do the work myself. What do you mean 2 different ways?
Hey Jim,
Definitely bearing clearance issues. Oil pressure is real low for running conditions. Just some advice, Buy new oil coolers. I don't know what happen to your original motors, but I have cleaned an oil cooler for an hour and still got metallic crap running out. Then I cut the oil cooler in half and I wasn't even close to getting all the metal out. See what your builder is using for rod clearances, usually .0025 is good for a stock motor and .003 for a higher performance motor. Check around w/ other builders and see what they recommend. Good luck and sorry to hear it.
My engine had low oil pressure when warm (502 EFI).
Complete tear down showed all bearings totally waisted and and one spun main bearing. Hard to see if the bearing tolerances was right, engine has been rebuild by former owner. However I discovered from reading here at OSO that it?s crucial to have the right oil bypass valve in the block.
Mine had the wrong one, wrong for remote filter and cooler.
FIERCE ALLEGIANCE
Originally Posted by hudsonslingshot
Hey Jim,
FIERCE ALLEGIANCE
Well... we cut open the 2 new filters and still had some flakes but nothing compared to the first ones. Starboard motor next to nothing... Port, little more. I'll be taking the filters to my assembler on Monday to see what he says... I'll post pics next week. Damn this sux! 2 years boatless and now after 2 months...boatless again.
man, go to NAPA and order an oil analsis kit, get two of them, they are $14 each. Follow instructions, mail to the physcial address, 48 hours later you have a good report, take that PLUS the oil filter to engine builder, this will tell you AMAZING things. Best $28 you can spend in this process.
FIERCE ALLEGIANCE
Dean;
I think I'm going to make this a std. in my maintenance going forward, however don't you think it's a little late for oil analysis now? I know the motors have to be torn down. What else can the report show other than there's metal in my oil? Just in a more detailed way?
