Modify early Intake to fit newer SBC ? >
Old 12-04-2006, 09:33 AM
SB
Received 3,171 Likes on 1,431 Posts
Default Re: Modify early Intake to fit newer SBC ?
Better late than never. I ran across these if you still need help -
http://www.holley.com/90748.asp
Weiand #90748
Wedge Kit to install an early style Small Block Chevy Manifold ('86 and earlier)on Late Model Heads ('87 to '95 cast iron heads); Includes bolts and instructions
SB is offline
Old 12-05-2006, 04:52 AM
Big Block Billy's Avatar
Smile Re: Modify early Intake to fit newer SBC ?
Thanks for posting the kit, It is exactly what I've been looking for. BBB
Big Block Billy is offline
Old 09-20-2009, 07:09 PM
Post
I ended up cutting an intake flange off a junk head , drilled it and installed drill bushings. I bolt it to the head, and drill out holes using a split point drill bit and a pecking motion. This removes the material , then I use an aircraft spotface cutter with the same size pilot as the bolt hole and make a perfect seat.
I use layout die and bolt the intake flange to make sure seat angle is perfect.( Maybe a little overboard).
No longer have a sloppy job nor make a mess and spend alot of time die grinding. I don't have to die grind at all. I grind off the casting numbers and stamp in Date and Tripps.
BBB
Old 09-20-2009, 08:05 PM
Originally Posted by Wobble
You could probably get the aluminium ones hard anodized for less than $50.00
where can you get a decent quality hard ano job done for $50?
I've got a couple of intakes and some exhaust manifolds I'd love to have done...
wtfo is offline
Old 09-20-2009, 08:35 PM
Post Anodizing
How long do they last ?
I have looked up and done alot of reading of anodizing.
Artificially building up the naturally occuring oxide layer of alumina. Then sealing the pore in the middle of each microscopic hex with clothing die and then boiling the part for one hour. Hardcoat anodize is anodizing done is a refrigerated sulfuric acid bath instead of just the normal room temp. This way allows for a thicker, in this case harder layer apx 80 Rockwell hardness.
It must be done perfectly, any chips or missed spots will allow crevice corrosion to get under and flake off the Anodized area. BBB
bwiencek
10
10-22-2013 06:16 AM
XtrmPWR
Do It Yourself, Boating on a Budget
4
09-08-2008 01:16 AM
pullmytrigger
5
12-01-2006 05:18 AM
JCPERF
Prop Talk
2
09-19-2005 11:36 AM
EWPE
0
03-12-2005 09:35 PM
Quick Reply: Modify early Intake to fit newer SBC ?
