Update - drive trim - goes down, not up
My port drive will trim down with the switch, but not up. Works fine with the trailer switch. I will check for loose connections, of course, but if I need a trim limit switch (or whatever Merc calls it), do I need to buy the whole friggin' kit? From talking to the parts guy, Merc only sells the entire kit which includes pretty much everything from the switch to the drive, wiring and all. Seems like a bit of overkill seeing as how everything is peachy if I just use the trailer button.
Suggestions?
Suggestions?
Click on : http://www.mercruiserparts.com/selec...sp?type_id=DRB
Click on your drive.
Click on "Gimble Ring and Steering"
Should so you the parts individually
Suggestions?
Suggestions?
