Need info changing from Carbed to Injected?
Here the question:
I currently have a 454 Mag 1991 Carbed.
Would like to make it fuel injected, have a connection to a fuel injection system off of a 1996 502 Mag EFI(includes fuel system/wire harness/ecu/ignition/manifold, basically everything)
would this be somewhat a direct bolt on to my current engine, and would it run correctly? Is it worth the effort? Would I expect to see any HP gains?
Any input would be greatly appreciated.
Re: Need info changing from Carbed to Injected?
http://www.offshoreonly.com/forums/s...=139469&page=2
My answer would be no, it's not worth the effort. Especially if you've never done it before. It will drive you nuts and not give you any better results than a proper carb.
Having said that, if you just want to do it for the learning experience, then good luck. It'll be a neat project. Let us know how it comes out.
boot
01-31-2005 11:27 PM
