BBC Bowtie MarkIV 10051107 Block... Where?
Re: BBC Bowtie MarkIV 10051107 Block... Where?
Just sell that engine and buy a GM 502 Marine Crate engine and be done with it. This way you'll have a brand new engine and wont have the headaches most people have after a rebuild. I wish I went that route when I first blew my engine. The time I finish rebuilding mine the cost was just as much as a new crate engine and half the time my ass was in the engine compartment. I finally was fed up with the problems so I yank it out and dropped a Crate in. Since Im no engine re-builder this was the best option for me. Plus I was back on the water within a week. Just my .02
MarineKinetics
Originally Posted by PatriYacht
Rm, do you know what the tall deck part # is? Thanks
Sportsman or Pro, (Sportstman 1 or 2 piece rear seal, Pro only 2 piece)?
Bob
Originally Posted by rmbuilder
Ian,
Bob
Bob
Registered User
Originally Posted by e8411a
What does 16 degree splayed caps mean? Also, I know the block I have is a "siamese bore" but what does that mean? .
siamesed means that the cylinders are right next to each other, with no empty space between them that water will flow through. Again, this makes the block more ridged, but not needed for what you are doing. Cylinders would look like this OOOO, instead of like this O O O O.
MarineKinetics
Ian,
4.494” Bore
Tall Deck Two-Piece Cast Iron Bow Tie Sportsman Block
Part# 25534367
The price on this block new is $165.05 additional compared to the std. production Gen VI replacement block.
Bob
4.494” Bore
Part# 25534367
Bob
I'm really just daydreaming at this point. However, I do get a company discount on parts and there is a SPO warehouse about a mile from my house .....
Ian,
See if they have a pair of Mark 4 Bowtie blocks ( Tall Decks ) in stock. I would like to get a extra set for spares just in case something happens to my originals. Here are the numbers.
Cast #: 14044807
GM#: 14044808
Chris
Cast #: 14044807
GM#: 14044808
Chris
The 107# is your casting number. Here are a few specs for your original block
GM#: 10051106
Cast#: 10051107
Cast Iron Block
Siamesed cylinder wall
9.800 deck height
4.250-4.560 ( bore range )
2.75 ( crankshaft journal dia. )
2 piece ( Crankshaft seal )
4.250 ( design max. stroke )
269 lbs. ( bare weight )
GM#: 10051106
Cast#: 10051107
Cast Iron Block
9.800 deck height
