454 Mag Fuel preasure
Can anyone tell me what fuel pressure i should use on the old 454 mag. I have a set of CMI stainless exhaust and a 230@50 & 600 lift cam. I have ported the heads a little and the intake as AZ speed do them and put on a massive K&N. I have a adjustable regulator but am unsure what furl pressure i should start with.
Has anyone got any other issues i should look out for.
Pistons are pretty expensive down in the south Pacific so want to keep them non see through.
Jason
Jason
![Cool](/forums/images/smilies/cool.gif)
![Thumbs up](/forums/images/icons/icon14.gif)
I run 8lbs 510 merc cam is 622ex 617in 254 246 114 dyno with bg 850 647hp tq 627 just but on a NICKERSON 1050 PICKED UP ALOT
GOING TO DYNO AGAIN THIS WINTER, GOING TO WORK ON THE merlin heads a little
. My pump is pre set. I think anywhere from 6lbs to 8 would be okay you have to see if it drops off on the top end. hope this helps
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
I think he is talking about an efi engine. In that case I think is over 38 @ idle. I have mine like in 40 because I have Cmi etop headers on my 502 efi.
