Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum? >
Old 10-23-2006, 09:16 PM
Default Re: Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum?
Originally Posted by zimm17
Well the oil pressure is just fine. 42psi at idle with the mechanical gauge. Just bought new senders, waiting to install.
I'll just have to figure out if it's worth the trouble of pulling the motor and putting on the $5k in parts for that extra power (75HP?). I'd hate to build a new motor when this one is basically new. Unless it blows up, then I'd build up a 540. Guess I'll just leave it alone for now.
zimm - might want to check to be sure the sending unit is compatable with the gauge. As I understand it, all senders are not compatable will all gauges. A guy from Lavorsi told me that when I ordered my oil temp sender and gauge.
Kidnova is offline
Old 10-23-2006, 09:33 PM
zimm17's Avatar
Yes I got the right senders- Faria gauges- Faria senders. I'm going to leave it all alone, maybe do a 540 next year if I decide to keep the boat.
zimm17 is offline
Old 10-24-2006, 07:01 AM
AIR TIME's Avatar
there is or was a nice 250blower/cooler and carb for sale in the classifieds the guy is down to 2500 for it. I passed on in in sept he wanted 3000. so I spent about 1800 picking up 20hp with a nickerson carb and new flame arrester lines went from 647 to 670 old carb was off a bg. I also have 510cu,so I thought I would wait and get a bigger blower in a couple of years. he ran a 540 with that blower so your 454 would pick up a 150 hp, with your stock set up easy maybe more, a lot more 250hp with the roller set up and cam keep the heads.
AIR TIME is offline
Old 10-24-2006, 08:32 AM
zimm17's Avatar
Blower is a good idea, but I don't want to cut a hole in my engine hatch- and i only have 3/4" from the hatch to my 2" flame arrestor with my edelbrock air-gap intake.
I think I'll wait a year and get a dynoflo, JC perf, or Roccard 540 engine if I keep the boat.
zimm17 is offline
Old 10-24-2006, 09:32 AM
I did a build on that exact engine back in '98. I went with a set of fully ported Merlin heads and the 731 cam. I blueprinted the short block and milled the heads to get the compression up to 9.4:1. I never dyno'd it, but the boat picked up an honest 7 MPH. You will have to spin the engine to 5600-5800 rpm though. More cubes is always nice, but the 454 in a light boat like your 22 will work very well. In your case I'd get a good set of heads with small combustion chambers and use some .027 Cometic gaskets to get the compression up. Just for the record, that 454 is in it's 3rd boat and still running great.
bobl is offline
Old 10-24-2006, 10:49 AM
BY U BOY's Avatar
I PUT 110 CC GM ALUMINUM HEADS WITH SRP PISTONS 10.71:1 COMP.FULL ROLLER RETRO ZZ502/502 CAM 502 INTAKE AND A 750 HOLLEY. ALL THIS ON A 91 7.4 IN A 21 SCARAB. SPEED WENT FROM 59.9 AT 5000 RPM TO 71.2 AT 4600RPM STILL TESTING PROPS SO I CAN GET TO 5150RPM.
WOULD LIKE TO HIT 75MPH ESTIMATED HP IS 530
SO YES I THINK THE GAIN WOULD BE WORTH IT
BY U BOY is offline
Old 10-26-2006, 09:38 AM
zimm17's Avatar
OH, I'd love a blower- but I don't want to cut a hole in my engine hatch. I only have 3/4" clearance right now.
zimm17 is offline
Old 11-07-2006, 07:22 AM
KAAMA's Avatar
BEFORE you contact Roccard about possibly building you a 540cid engine....or ANY engine for that matter, a word to the wise is that it would be in your best interest to do some extensive research on Roccard and the some of the not so happy guys from OSO who have entrusted their engines to him in the past. Search the OSO archives.
KAAMA is offline
Old 11-07-2006, 08:12 AM
zimm.......Might wanna read this post twice.
Kidnova is offline
Old 11-07-2006, 07:55 PM
nordic95's Avatar
ZIMM,
Read it three times,and then maybe once more for me.
Nordic95
nordic95 is offline
Quick Reply: Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum?
