Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum? >
Old 11-07-2006, 08:12 PM
offthefront's Avatar
Default Re: Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum?
Originally Posted by Stingray69
Get it working right, then shop for more cubes, keeping the 454 as back up/put back, when needed/selling. A 500hp, freshened, will get you way faster, way easier, than surgery to the 454.
Put 5K into the 454, and you'll STILL be wanting to put those add-ons on a 502.
how bout a 502MPI ....500 efi cam ...crane roller rockers ...Isky lifters ..GM HP heads ...ECU remap ...everything but exhaust .... 8K .......m
http://home.comcast.net/~mbell53/startup2.htm
offthefront is offline
Old 11-07-2006, 11:02 PM
Wink Re: Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum?
I'll say it again here! "There's no replacement for displacement!!" especially in HiPo boat motors!!
Ray @ Raylar
Raylar is offline
Old 11-08-2006, 08:02 AM
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
How about stroking it to 496?? You could also use toplines for a fairly reasonable build.. And Or you could go with a procharger M1 or M3 unit.. (check your email, I got your question from the Donzi site as well.. )... Lastly if you dont want want to supercharge & you want huge power then using a big CU IN build is the way to go.. call us if that may interest you, we have quite a few options.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 11-08-2006, 07:27 PM
Jamie ..I'm building 2 stroked MIVs now .. to 496's ...everthing is new cept the blocks ... Edlebrock marine heads ..all roller VT ....850 Holleys ..cant wait to see how they do ....
Old 11-08-2006, 08:15 PM
Commercial Member
If they are done right they should be strong runners! What intakes are you going to run?? Jamie / Lakeside
Old 11-08-2006, 09:04 PM
Team Dysfunctional
Hot Boat's Avatar
Originally Posted by zimm17
OH, I'd love a blower- but I don't want to cut a hole in my engine hatch. I only have 3/4" clearance right now.
If you do decide to cut that hatch I ave a great deal on a blower, intercooler, carb , cam, lifter, rockers, and all the parts to make that 454 about 575 hp . PM me if your interested
If it aint broke .... I can break it....
Hot Boat is offline
Old 11-09-2006, 08:56 AM
We got Victor Jr's .... but have been told the Darts make a little more power ... Probably let Dean Nickerson set up the Carbs ... only thing confusing is I talked to him about whether he would recomend the Holley or Demon carbs he told me they is no difference ..They are Identical ....m
Old 11-09-2006, 09:37 AM
Commercial Member
The holley & Demon are very similar. The Demons are a bit more tuneable & can be tricked out a little bit more..
Croozin2
18
09-27-2007 07:31 AM
dagah2x
05-31-2006 09:45 AM
zimm17
9
09-24-2005 04:07 PM
rcannon
2
07-12-2004 10:02 PM
Quick Reply: Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum?
