are all bravo couplers the same? >
Old 10-02-2006, 07:58 AM
98itrwhite's Avatar
Default are all bravo couplers the same?
are all round style bravo one coupler the same? i need one for a mark4 454. thanks
98itrwhite is offline
Old 10-02-2006, 08:07 AM
Default Re: are all bravo couplers the same?
there are two types for the bravos,the standard one has the aluminum insert and the heavy duty has the steel insert.the standard works perfect for most applications.
proboat-wes is offline
Old 10-02-2006, 08:23 AM
98itrwhite's Avatar
so this should work then
http://cgi.ebay.com/ebaymotors/MerCr...spagenameZWDVW
Old 10-02-2006, 08:29 AM
BajaRunner's Avatar
I was told by my engine builder not to use the steel insert for a normal application. Ive got warmed over hp500's and i use the aluminum.
BajaRunner is offline
Old 10-02-2006, 11:07 AM
Yes it will work
ghittner is offline
Old 10-02-2006, 12:15 PM
Charter Member #139 /Moderator/Platinum Member
klaw's Avatar
I have a couple used one that I replace with the new style the ar in ok condition never spun have a ltlle rust on them.
They were from 500 hps and I replace them just as insurance as I was upping the motors horse power and did not want to take a chance
let me know if you are interested
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 10-02-2006, 05:42 PM
I have one never used $200 shipped to your door.
cobra marty is offline
Old 10-02-2006, 06:19 PM
offthefront's Avatar
Marty .... I'm interested in the Coupler .. Is it the new style with grease fittings ? Steel Or Aluminum ?
98itrwhite .. has first shot ... thanks... mike
offthefront is offline
Old 10-02-2006, 07:20 PM
Big Block Billy's Avatar
Beware of used couplers on e-bay. I have been stiffed at least twice. One was advertised as in new condition.
Use the spline grease, and clean and inspect any used coupler and install with Merc. factory alignment tool. BBB
Big Block Billy is offline
Old 10-03-2006, 06:45 AM
98itrwhite's Avatar
thanks for all the response's. i found one local. i am trying to get it back togather for a final run this weekend. thanks again guys
Quick Reply: are all bravo couplers the same?
