Oil filter for '96 502 efi
My new boat has a beefed up 502 efi, and the previous owner was running a Wix oil filter instead of the merc. Any reason for this, should i just go with the readily available merc?
The filter that is on it now is a Wix Racing p/n 51061R. I was at Farm and Fleet checking out the price of the Mobile 15W-50 and also saw that Mobil has a extended performance oil filter, P/n i saw was something like MI-301. Anyone run either of these or have any info on these filters........
Can these filters be mounted upside down? I thought the Merc. filters had a check valve in them that kept the oil from draining back since they are inverted.
Registered User
how's the filter going to drain if it's upside down. It will always stay filled.
The M1-302 has the advantage that it uses a synthetic filter element. It won't swell up like paper elements and cut off filteration if there is moisture in your oil.
Originally Posted by the duke
Gravity if there is no check valve. It will drain back through your lines/pump and into the pan.
