496 HO not starting any ideas >
Old 10-19-2006, 10:45 PM
Rough Seas Lie Ahead
Reckless32's Avatar
Default Re: 496 HO not starting any ideas
Tighten the cable to the starter. Happended to me late last season. Tightened it up and no more problem.
Reckless32 is offline
Old 10-20-2006, 08:46 AM
Originally Posted by ratman
smack the starter with a hammer, if it starts the brushes are about worn out
wahahahaha LMAO
If it doesn't, take a bigger hammer... then use some chicken wire to put it all back together... Holy sweet Ratman, am I glad you're not a doctor. LMAO
merlyn1965 is offline
Old 10-20-2006, 02:09 PM
Sounds reasonable will use my medical hammer, still can't find the starter though anybody have a schematic of the engine, should I be able to reach it from the top??
Regards
Rick
docricky is offline
Old 10-20-2006, 08:03 PM
Rick, the starter is aft under the stbd side exhaust manifold by your bellhousing. So yes you should be able to get at it (might [will] get some scratch on your arm). if you go in between both engine. I've mark where the location is with the arrow on the pic.
Old 10-27-2006, 12:54 AM
Wink Re: 496 HO not starting any ideas
There is also a fusible link on the cable at the starter post connection.Use a continuity tester check this before you remove the starter, we have seen these go bad and kill power to the starter solenoid and hence no start. Turn the battery power off before you do this test or work on the starter. Shorting the battery cable lead to the starter can lead to some serious arching and damage!
Ray @ Raylar
Raylar is offline
Old 10-31-2006, 10:30 AM
Make sure the main ground lugs, on the bell housing are tight, and making a good conection.
Island Hopper is offline
Old 10-31-2006, 12:30 PM
could it be hydrolocked have seen a few 496's do this this year all in different models. hopefully not
phil0460 is offline
Old 10-31-2006, 07:09 PM
Reckless32's Avatar
Had the same problem on one of my HO's fall of 2005. Turned out to be the battery cable at the starter was loose on my port enige. Initially just took one of my poles to my cover and gave it a shove tight getting it to start. Eventually took a couple of extensions and a universal joint socket adapter and got it tightened up. No problem since. Beyond that work your form battery up front to the ignition switch cleaning and tightening.
288sunny
Do It Yourself, Boating on a Budget
3
07-15-2008 08:11 AM
TeamPSI
23
12-10-2007 05:23 PM
bn
4
01-15-2005 07:40 AM
Harper220
25
12-09-2004 06:19 PM
01 272 Boss
30
04-19-2003 09:51 AM
Quick Reply: 496 HO not starting any ideas
