454 Mag MPI ran great ..... but only to 4000rpm >
Old 10-23-2006, 12:16 PM
mats's Avatar
Default Re: 454 Mag MPI ran great ..... but only to 4000rpm
The timing is set without load in service mode. You either need a scantool or a paperclip to jump the A and B terminals of the DLC. Set initial timing to 8 degrees.
mats is offline
Old 10-23-2006, 10:03 PM
Dave_N's Avatar
Originally Posted by StillHaulin@61
Mechannic scanned engine and indicated a knock sensor alarm had occured. Cleared alarm condition and said to try again. Same result (4000rpm) occured..
If it's setting a code 43 or 44, it will default to full retard (5 degrees). That could knock a few hundred RPM off the top end.
A repeating code 43 or 44 could be due to incorrect timing, mechanical noise or induced signal from a plug wire. Make sure you don't have a plug wire touching the knock sensor wire(s).
Dave
Dave_N is offline
mg503
Baja
14
04-03-2013 04:50 PM
mittens
6
06-06-2008 04:54 PM
cliff3466
1
03-09-2008 08:10 AM
MC-BOYS
7
07-11-2006 02:15 PM
Elite Marine
Pantera
0
08-18-2004 07:48 AM
Quick Reply: 454 Mag MPI ran great ..... but only to 4000rpm
