Prop Questions Hydromotive-bravo
Can i use the thrust washers from my Bravo 1's on a set of Hydromotive Q !V's.If not what should i be using?What would Bravo 1 22 pitch props be equal in size to a Hydomotive style.Locking tabs the same? Help.Thanks
It depends on how old your bravo's are. The older solid hub bravo's use a small thrust washer. The newer bravo's and the hydro's with the removable hubs use larger thrust washers. You can not use the small washer with the newer bravo's or the hydro's.
I had new style bravo's.Hydromotives fitted straight on.Had to use the old style short castle nut though.Thanks
