Blower experts please advise fuel system requirements for Procharger M-1
I have a 7.4MPI with mag internals and Merlin heads, roller/rockers. Unfortunately I did not up-grade the stock injectors and detonated after 3 re-maps. I plan to up the injectors to say 40#s, re-map accordingly, install a LM-1 recording O2 sensor with fuel pressure logging for final tuning. I have the stock procharger (red regulator) set up with a red vein pump feeding the stock 7.4 mpi fuel-cool/stock pump. Do I need to change any of the fuel delivery system? Can I keep the fuel/cool? I had in excess of 60#s pressure with the smaller injectors programed @ 90% max duty cycle. What new injectors should I use and what W.O.T. pressure should I run? Thanks for your help.
I think you are fine with fuel delivery but do need an injector change. I have to go back and look at the injectors on my Modified M3 motor. Arizona Speed and Marine was a big help with the injectors and remap as well. 250 hours no motor problems.
I supported 700 plus hp with stock 42 or 43 lb injectors at 75-80 psi at 80-90% duty cycle so I'm sure you could use something that size for what your trying to do,mine were fine at 70-75 psi with less boost around 650hp. Are your injectors short and stubby (micro's or mini's they are sometimes called) or long?Here is a pic,the smaller one is a stock merc,the longer one is something I went to when I went bigger yet,Smitty
Thanks for the response. It has been a year since I have had the injectors off but I think they are small. Mark @ performance said the good news is that the injectors on my set up are more popular as a stock item and therefore easy to replace. The motor ran all summer on the stock injectors, so I am probably not too far off. I thought about putting what ever volume comes with a stock Merc 500 or 525. Any body know what comes with either of these engines?
I have 42# injectors that were cleaned and flowed that I ran in my M-1 Procharged 468 which produced 638 HP with perfect A/F Ratios and EGTs.
I am selling them and could have them cleaned and flowed again prior to sale and send the data with the set.
You have the correct fuel system for your application.
Kirk
Kirk
t500hps
01-10-2007 02:56 PM
