Whipple or procharger for 7.4 >
Old 11-20-2006, 07:41 PM
Pirate of the Chesapeake
Fenderjack's Avatar
Default Re: Whipple or procharger for 7.4
Just go look in a jegs or summit catalog. You can pick up a nice eagle rotating assembly for 2k or so. You will be fine with that..
Fenderjack is offline
Old 11-20-2006, 07:42 PM
Magnum25's Avatar
any etimates in all this???
Magnum25 is offline
Old 11-20-2006, 07:43 PM
Fenderjack's Avatar
As far as what price, speed..
Old 11-20-2006, 07:53 PM
Magnum25's Avatar
if you put the things you said what would the stimate be
Magnum25 is offline
Old 11-20-2006, 08:00 PM
Fenderjack's Avatar
Without a blower, your prolly talkin 4k, With machine work, thats putting it togather yourself, with a blower tac another 4 to that at least, new heads, another 2k or so. The first thing is yah need to find out how much you have or want to spend, go from there, again if money isn't a problem just get the stuff, lol
Old 11-21-2006, 02:09 PM
Whipple Charged's Avatar
You shouldn't have a problem SC'ing that motor, keep the boost below 6psi, intercooled, run around 11.5:1 @ WOT, run same timing as stock, only use 91-93 octane. Motor has 8:1 compression and we've supercharged many of these in carb'd form. I actually did one on a EFI version, it's gone over 700 hours, non intercooled 7psi. Certainly not what I expected, but the low compression, low water temp, fuel through SC really makes this a save setup.
Increasing the cylinder pressure with 6lbs of boost will not hurt the rods, increased RPM's will be the worst thing you can do. In all our years, rods and crankshafts break far less than 1% of the time on stock applications.
Thanks,
Dustin
Whipple Charged is offline
bajaboy2004
15
08-06-2004 07:43 AM
shawn
1
02-08-2003 04:51 PM
MIKE H
6
05-27-2002 11:10 AM
Airwolf767
Fountain
5
03-27-2002 11:03 AM
Quick Reply: Whipple or procharger for 7.4
