Will a pair of HP500 GIL Manifolds fit a Merc. 454?
Location: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
1 Post
yes and you may need to find a way to mount the shifter mechnism and oil filter if it mounts on your original riser bolts.
I believe imco may have some brackets but you may have to check bolt location.
When I installed my Gils I moved the oil filter to the transom on a bracket I fabbed, very easy to change the filter with -0- mess with a plastic jug bottom held under it. The shift bracket had to br moved outboard on the riser, I did not have enough clearance for the carb plumbing.
The manifolds will bolt right up without a problem. We have adapter brackets available if you need them.
http://www.hardin-marine.com/product...ccessories.htm
Where To
I've got an original set of brackets (2) for twin engine set-up. $50 shipped in the USA. Pm me if interested!
Dave
Dave
