Aircraft wiring on a 500 EFI?
I am assuming that the motor is sealed and to sanctioning bodies spec.....it is on the water pump , intakes bolts , fly wheel and has a serial # on all the tags.....WHat gives.
Bryan
Bryan
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
Bryan, I too am not sure what your question is??? Feel free to call me tomorrow ( I will be in the shop all day)... I can try to get you an answer to your question.. It probably just has to be rephrased..
Jamie / Lakeside 570-639-2628
![Smilie](/forums/images/smilies/smile.gif)
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Forum Regulator
They seal them with little marks of paint on all of the bolts. They do not use "safety wire" as we used to call it in motorcycle and PWC racing.
Bryan
1 Post
My 500EFI has the wire being discussed on at least one intake bolt, haven't seen any elsewhere on the motor. Mine is a 2001 year model, and I believe the wire is a tamper seal, desiginating the motor was assembled by Mercury Racing.
Larry
62 Bel-Air 409
260 Eagle XP HP500EFI
2002 Corvette M6 Coupe
Larry
62 Bel-Air 409
