Air conditioning duct material
Re: Air conditioning duct material
Yeah, if you are running duct thru an area where you don't worry about mildew then run whatever you wish (pvc, flex hose, etc). On long runs, though, you'll bleed duct temp to the surrounding compartment so take that into account..
On compartments where mildew can be a problem, you have to run insulated.
Also be aware, that if you "use a compartment" for a duct (by pressurizing a closet, etc) that you will get condensation in that compartment as well.
Ginger or Mary Ann?
Thanks for the replies!
I ended getting the insulated duct just for a peice of mind. Only 1 spot where it is too thick is where it goes inside of the power panel. I may either remove the insulation or thin it down just for that spot. The rest is no problem.
Here's my setup, if you see something wrong, speak up.
The A/C unit is mounted inside the counter in the location where the drop in cooler was, just to the left of the sink. The supply hose travels under the sink and up thru the AC/DC power panel to a TEE inside the plexy panel at top feeding a 4" round register right above the shorepower panel on the 45* angle, then across the top inside of the plexy panel above the mirror, into the side cockpit storage void (where the insulated duct is needed) then down and to a 2nd 4" vent near the door. The cabinet will get a large vent cut in for the return supply air.
1 consern I ran across.
The outer duct covering is of a 'metalic' covering. Looks like aluminum foil. It doesn't read continuity using a meter. The duct will be a tight fit inside the power panel and there is the live wires for the shorepower panel. I don't 'think' there will be a shorting problem if the duct touches the wiring since it shows no continuity, but not sure. Thoughts?
If your concerned about shorting,go to a local HVAC supply house or home depot. You should be able to get insulated flex duct where the outer skin is plastic, however all the flex i've ever used has a wire inside to keep it round.
Dave
Dave
21 and 42 footers
Dave
Dave
Ginger or Mary Ann?
Yep, thought about that wire today. That may be a little to chancy going the proposed route. May have to go back to plan B and exit the supply to the left side by the entry door, then up and over to the other vent, eliminating the need to run the duct thru the power panel.
Also thought of making a door/vent to keep from cuting a large hole in the cabinet and saving my original door.
Thanks again
Thanks again
If you plan to run on shorepower and run the AC at night while you sleep, you'll want to address compressor noise with it inside that cabinet. Also make sure you sit the unit on some rubber damper feet. (and believe it or not, mount the circ pump on rubber mounts too).
Also, in the cabinet where the unit is mounted, glue outdoor carpet on all of the hard surfaces in the cabinet to kill the noise, and make 2 sound killers by gluing 2 pieces of carpet back to back and hanging one of them so that the air has to go around it to the evaporator, and also put another about an inch behind your intake slots. I did this on both units in the SeaRay and I can't tell when the compressors turn on in the dead of night, except for the relay click.
