Putting an EFI Whipple on an NA HP500
FIERCE ALLEGIANCE
Is this as easy as it sounds? The EFI kits bolt to the block, they come with the wiring harnesses and I'd just need a computer. Right?
What am I missing? Who's done it?
Pirate of the Chesapeake
For the most part yes as long as it comes with the pcm, harnes to hook up to your engine, also If you are running stock(cast) psitons, I would recomend running too much boost, other then that you should be ok
John
John
You can buy the entire kit from Whipple. I called them about it a few months back when I was considering EFI Whipples on my HP500's. I think it was priced about $11k.
AKA NoMoBoatin
FIERCE ALLEGIANCE
Originally Posted by docmanrich37
You must be getting a hell of a deal if its priced at $11k. ![Big Grin](/forums/images/smilies/biggrin.gif)
AKA NoMoBoatin
Originally Posted by Blue by You
$11M each most likely with delivery and computers.
