How much HP with this Combo?
Hey Guys,
I appreciate all of the comments and advise, please do keep them coming; it's a long winter...
Some new info:
I spoke with Tyler Crockett about this engine combo as I'm likely going to ask him do the programming of the ECU.
He told me that a 9:1 compression 454 does have the potential to make 500HP with the GM Heads, 500EFI cam, and headers. Mine will likely make 20HP less with the aluminum manifolds.
On the question of the crank, Mr. Crockett said the crank should have no problems with 500HP if the rotating assembly is balanced properly. He did agree that I should replace the 3/8" bolt rods.
Some new info:
Patrick
Patrick
Pat
Make sure to do the relief in the block that will unshroud the valves and helps with power.
Originally Posted by AIR TIME
Aren't the heads gen 5 on the 500efi,you have gen 4 block?? I though the water jackets did not line up??
Hp isn't the problem with that cast crank. Rpm is the problem. There is no way your engine will make 500 hp or even close to 500 if you redline it at 5200. If you want to redline it there, use a smaller cam. It will idle better, be easier to dock, and it will make just as much hp with more low end torque.
Originally Posted by Smitty
Pat
Patrick
Patrick
The heads are from a 1996 Gen VI HP500.
There should be no mismatch issues...
Patrick
Patrick
My goal is to make at least 1HP per cube and I think a 454 can make 454HP at 5200rpm...
Patrick
Patrick
Originally Posted by Pat McPherson
I do remember reading about notching the bores on 454s. Once I get the engine torn down, I ask you guys how to do it then. I'm assuming I'll have to go with pistons with a little more bump to keep the compression up.
Registered User
The last slightly modified 454 we built made right around 480 HP at 5500 RPM. It had
GM 049 heads with 2.19 intakes
bore notched
9-1 CR
victor Jr intake
850 Holley
Crane 731
