Donovan Aluminum block
smitty,
ive never seen one of the donovan blocks but the al blocks that i have built were designed comprehensively differently that an iron block... perhaps for the reasons you suggest. i would GUESS that if you just cast an al block IDENTICAL to a iron block you would probably be right but the ones ive worked with ( all euro and cosworth stuff ) give up nothing... and the weight savings is substantial and they are easier to cool etc... an all around good deal in my opinion... having said all this, i have never built an al based american style v-8.
in a pure racing application its a "must have" but in a hot rod marine application my suspicion is that the cost benefit/hassel analysis would fail. but that is pure speculation on my part never having actually done it. and whoever suggestedthat closed cooling w/ corrosion inhibitors would be requirement is most probably absolutely correct
My blocks are 12 years old,fresh water only,and show no signs of corrosion at all.The trick in a marine environment is controlling all your temp.Without control the water and oil would never get above 90*so you have to use restricter plates and thermostats in the water system and oil thermostats for oil temp control.Condensation is the biggest problem with the cold alum block ,but is easily controlled by keeping the oil temp above 185 with the thermostats.The one really good feature of alum is if you drop a valve or something and loose a cyl ,you just replace the liner,not through the whole block away !
I don't know what a Donovan Alum block weighs, but over the years aluminum blocks have ranged from 98lbs to as heavy as 157lbs. This will save anywhere from 100 to 160lbs over an iron block.
On a 30ft with 600hp BB's that's about 2mph. Probably not a bad compromise considering what two 600hp BB's cost in the first place. Probably less than 1mph on a high HP 40fter
I've never seen any direct comparisons for HP losses, but i would guess it probably would be a big deal once you go SC. Especially for longevity. I know guys that had Chevy factory sponsorship that could have any parts they wanted that still ran cast iron.
Alum. BBC's are certainly a different casting, but not a total redesign. If you look at a good dedicated aluminum racing block, you'll notice details like webbed pan rails that come down below the crank so that the caps bolt in from both the bottom and the sides. Also, split blocks with head studs that run all the way to the crank journals, etc.
Also, remember the high boost turbo F1 engines of the 80's. They were cost is no object motors were every gram counted and they were iron blocks.
Originally Posted by stevesxm
smitty,
Now your scaring me. I found what appears to be a nice set up. 60 hrs (used) 572ci 11:1 ( I was told it runs pump gas)
Has all kinds of top of the line parts: Jezzel shaft ,corrillo rods, lunati crank,solid roller,I think merlin heads, monster dominator carb, external oiling system with some $1400.00 oil pan, etc, etc, bla bla bla. It's supposed to make something like 800-hp @5800 and 900-@ 6500rpm
apparently built to spin like that. Does this seem feasable?
well... it seems a bit optomistic to me but if it is as good as he says and the price is right, then a day at a dyno ( not the guy that built it ) might give you the handle on a good deal. if the claims and condition can be validated, ... and i would do a leak down on the dyno when its warm... then how can you hate it ?
Those figures are very feasable,it just takes good parts to do it. I make 1040HP at 7000 rpm,& 900 ft. lbs. torque @6000.I'm 600 inches@13to1 compression ,n/a,kinsler fuel injection,on race gas. Pump gas at 11 to 1 with a big cam is borderline but might work.I would not walk away from an engine just because it has an alum block.Just do your due diligence,who built it,who maintained it,who had it apart and why.A leak down test will tell you a multitude of sins,if you can get some oil,do an analysis,that also tells you a lot.Even the guys at Sterling who are the best ,will tell you that if you run one of their engines wide open all the time there're only good for 50 hrs. before refresh,run um easy there're good for 250 hrs.
Thanks guys,
I will see if I can get a parts list or some kind of build sheet. I dont think it's asking too much for a leak down and dyno run. If it's not very practial to use someone elses dyno, What do you recomend I do to insure a fair pull and an accurate reading.
I know about the air temp base line but what else or is it just to dificult to monitor?
PS: myskater32, that sounds like a nasty son of a gun
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
We are toying with Aluminum heads on our race boat this year and our engine guy who is very good is going up 1 compression point from the current cast Merlins. This is the same set up as his own engine that makes 1100 HP on 100 octane max and 1054 HP at 6000 operating RPM. His engine runs reliable. Interesting thing is that he likes to keep the combustion chamber as small as possible to concentrate the heat into the aluminum so it gets dissipated quicker. Hence, the extra compression. The thing is that if we change pistons and leave the chamber the same size. Say 118 then we can only have .75 more compression at most. The other interesting thing is that the more compression we have, the more RPM he is happy for us to run, although I must say a sustained 6200 rpm is playing mary hell with the valve train. We have 8 races and it’s looking like lifters, push rods and rockers at half way point to be reliable. Lastly we have three tubes welded to the block each side and bolts tapped into the bottom of the heads to help hold them on and that with all cast iron. We have done some research on Aluminum blocks and the general consensus is that for race marine use at least, we would all much rather have some kind of sexual disease as it would be easier to get rid, more fun in the initial stages and about the same amount of hassle during ownership. The cost of remedies and downtime would be much less with the sexual Disease as well. Just my thoughts but we have spent some fair amount of time making them. Jas
![Cool](/forums/images/smilies/cool.gif)
Last thing is our engine guy is expecting a solid 100 HP increase with Ali heads and that with a starting point of 875 give or take 10. I think stay with cast iron block and spend the money with Jessel, whipple and a cool 4 blade to give extra lift to match the extra weight. Jas
