Blower Cam Advice and Help! >
Old 12-25-2006, 12:39 PM
Elite Marine's Avatar
Default Re: Blower Cam Advice and Help!
I have an Aeromotive Fuel Pump, regulator and Peterson Filter with one season on it for sale in the swap section.
Great price for the package.
Elite Marine is offline
Old 01-02-2007, 09:41 AM
johnnyoffshore's Avatar
Originally Posted by TylerCrockett
I would have Cam Motion custom grind something around 630-650 lift and 238- 246 Duration on a 114. With that little engine I would have used a 8:71 blower and 2 -750's. That 14:71 is eating Horsepower that you are trying to gain.
Thanks Tyler,
I will pass the info to the maching shop.
johnnyoffshore is offline
Old 05-27-2007, 05:26 AM
We went with the followoing: block is a GM Bow Tie 4-bolt main tall deck-100 over 454 (475CI), will be a fixed/mechanical roller cam, the heads are Reher-Morrison Brodix aluminum CNC ported heads and some additional port work done to the exhaust with a little clean up work done to intake, using Crane Gold racing full roller rockers, oiling system is a Weaver dry sump system with Weaver pump and tank & Mercury Racing SC1000 oil pan, the crank is a LA Enterprise Kryptonite stock 454 length, the rods are Carrillo Rods little longer then stock length (but not stroked) SRP Pistons flat tops at 8 to 1 comp, The Blower Shops 871 with Teflon in the rotors, intake is port matched with Keith Eickert Performance Products intercooler with Cupro-nickel core, 2 Nickerson Performance Marine 980 cfm Blower Comp Carbs recommended by Dean , Fluidampr Harmonic Race Balancer, Jesel belt drive system, Keith Eickert Dual Stage Extreme Raw Water Pump and water crossover setup with 2 Keith Eickert sea strainers, offshore water pickup & out drive pickup, MSD 7ML-2, MSD Pro Power Coil & MSD Marine racing distributor, Presolite alt and Tilton starter, CMI Comp SS big tube headers with 4" w/ dry pipes. Motor is finished and will be dyno'd next week. Wednesday, May 30! Looking to go racing with OPA in 2008. Working on getting some sponors.
Old 05-27-2007, 07:34 AM
Good Luck!
mrhorsepower1 is offline
Old 05-27-2007, 09:22 AM
PatriYacht's Avatar
That sounds like a wild engine! Wish I had a couple. Will you be in St Clair?
PatriYacht is offline
Old 06-03-2007, 09:59 AM
Blower Cam Advice and Help!-aquaholicracingmotor.jpgPics of Aqua-Holic Racing blower motor and link to video of motor on the dyno:http://wallysprecisioninc.com/video/..._aquaholic.mpg
chewy1955
0
11-10-2005 05:12 AM
STRAIGHTPRIORITY
04-18-2005 11:48 AM
fastlane40
30
01-20-2005 05:53 PM
Panther
3
12-23-2004 11:57 AM
cougarman
10
07-09-2003 11:15 AM
Quick Reply: Blower Cam Advice and Help!
