new raw water impeller..now difficulty priming
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
Originally Posted by Sydwayz
Do you run in a lot of shallow water? Perhaps you need to flush the entire motor and all oil/fuel coolers & heat exchangers (if equipped) manually.
You could have sediment in the bottom of your cooling system which is affecting flow and/or the thermostat.
This probably isn't your priming problem, but could be your creeping temp issue.
![Smilie](/forums/images/smilies/smile.gif)
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
I will double check the hose between drive and transom. The manifolds and risers are about year old and always flushed well . I will take supply hose off and blast it backwards to make sure drive is clear. Since the impeller spins so freely in the pump as compared to the way it used to , I am guessing the bore is worn out and that is the deal.
Ginger or Mary Ann?
Haul it to the lake. Might be nothing more than 2 sets of bad muffs since it works fine once you get it primed. Sure you haven't toasted the impellor during your trouble shooting?
What type of 'tee'do you have... The Perko with a check valve? Maybe a sticking valve. Also make sure the hose attachment fitting for the tee flushing either has the cap on tight (with the gasket of course) or a shut off valve is closed. If you are sucking ANY air in from that hose adapter, never will pull water from the muffs.
Hunt around for a large plastic tub that you can lower your drive into. Lower drive into tub and run hose into tub.
The "T" is Vovlo Penta part (they added them in like 2003 I think). It is little different than Perko is just a T(no check valve). Since there is no valves obviously the cap is more important and I have checked it along with the hoses for any leaks and they all seem fine.
Update: I found a NOS pump, a local guy that salvages boats has some new parts, anyhow he had a pump from when he purchased a parts lot from a dealer going out of business. New pump turned way stiffer, much like pump used to. I took it apart and side by side the wear on the bore was very noticeable on my old pump. It primes and seems fine on the muffs, I will try to water test it today. Thanks for everyone's help/advice.
