Optimum air / fuel ratio for marine engine
EGT Temp. vary wildly depending on how far the prob is away from the exhaust valve.On a dyno the probes are usually 6 inches from the valve.This is hard to do on a marine water jacketed header. I had mine in the exhaust port next to the header flange,i saw temps in the 1700*range.The dyno showed 1300*with the probs 6 inches downstream !
MarineKinetics
Some helpful information regarding EGT and tuning parameters;
http://www.maxracesoftware.com/egt_probes.htm
Bob
Bob
Bob
Bob
100*.5= 50 lb/hr
+ 20% = 60 lb/hr
You could just multiply that by hundreds and that should get you there. So, 700 hp = 420 lb/hr or about 60 gal/hr or 1 gal/min. Just be careful when sizing your fuel pump to know the operating pressure range for the pump. A pump curve is always best to know that your fuel delivery will be adequate at your operating pressure.
Rene
If the flange is thick enough where it mounts to the head you can drill there.Most EGT probes are 1/8 pipe thread,about 5/16". Be sure you don't get into the water jacket , or you're S______!
