Melting Intercoolers
Re: Melting Intercoolers
Something to consider look at what another leading supercharger company has done to there supercharger.
I beleave looking at this. This port is to releave the boost at
low Blower speed high engine vacuum.
Pretty cool
This should help with the heat.
Pretty cool
I've seen this problem occur during start up, mild backfires igniting raw fuel soaked intercoolers usually due to fouled spark plugs, leaking intake valves or just out of tune. Charge temperatures usually never reach hot enough to melt aluminum.
What kind of fuel system in the boat?I dont think duel needles are necessary but the bigger needle and seats help
Check these out only thing I could find yet.
I have not called CSU on these yet.
Would need 1250 dominator equivelents though.
Fuel Aeromotive 2000s with 10 feeds 8 returns.
-8 feeding each bowl
Considering the belt driven Aeros. The 2000,s do move some fuel though.
This was a standard alluminum Lee core. Most everyone agreed that SOMEHOW I had ignited fuel pooled on the intercooler which melted it. Hope this helps.
Belt driven pumps are generally needed after 1200HP.I found that out this year
Those CSU Bowls look like they may bolt right on my King Demons.
I have melted one on a stock Merc 900SC, and this is what is believed to occur. I had ran the boat the day before and everything was great. I got up the next morning headed to a pokerrun. After pulling out of my marinia I started to get on plane and I noticed the motor coughing a little and then it died. When I restarted it, which didn't go as easy as usual, I noticed ALOT of steam coming out of one tail. This concerned me so I Idled back to the dock, pulled the Core and knew something wasn't right. I rigged a way to pressurize the core but it wouldn't because of all the holes from being melted.
info I am looking for. What chargers were you running at the time?
Thanks for the repsonse.
Gerry
