Trim Tab Indicator Install
What's involved with installing a set of tab indicators? I looked on Trick Marine, and they have an indicator kit for $180. Does this have everything included, cables & all? What's involved in the install? I assume drilling holes in the transom to attach the cable, and obviously cutting a sizeable hole in the dash as well. Any suggestions? The boat is a 24 Superboat with K-Planes, the big cast(?) aluminum jobs.
Thanks!
Thanks!
Re: Trim Tab Indicator Install
no cables. they are 33c series. yes big hole in dash. use plenty of silicone around thru hull holes in transom.
merc style indicator set ups for drives around 250 each kit.
use a good cable, and dont over tighten the back plate on the indicator panel, they indicators them selves slide easieer that way,.
I have a used set cables and everything else coming out in the next couple of weeks the pannel is the MERC K PLANES IN BLACK. its coming of my 24ol baja so they would fit a 24 superboat. I am going to a 3 pannel set up . art
Thanks!
Thanks!
1. Indicator [on dash]
2. Cables
3. Actuators [on tabs or drives]
If you need to any information on installation, just give us a call. No obligation.
Fred
oh yeah, be carefull when your putting the cable assy. onto the back of the panel, cause if your noy and the lil orange/ white indicator pins pop out you'll be like this,,,,,,,,,
Thanks for the info. Sounds like it will probably run about $500 or so for parts. I have it on my to do list. The first two things are to complete the hydraulic steering and get the prop fixed up. Indicators will come after that. I think I'm ordering the steering kit in Late Feb, sop that wil get it moving.
Thanks again!
Thanks again!
