Kieth Eckert Manifolds make more power than CMI Headers
Re: Kieth Eckert Manifolds make more power than CMI Headers
I did not realize that the KE link did not work. Another try.
http://www.keitheickert.com/products/Exhaust/
All great comments/insight. Thanks.
For the record the KE cast aluminum manifold add says the exhaust runners are 32 " long. As far as why not in racing my guess would be the design inflexability of the KE unit which would not allow any tuning/design optimization that tube headers can more readily accomodate. Sounds like the tube ID polishing was an Extrude Hone type process. Expensive. Good question as to if this is still being done.
I called KE and asked. They do not Extrude Hone / polish the exhaust runner ID's. They are as cast.
There is only one BBC confirguration and it does not fit the 496.
We used these for years racing superboat class with KE 1100's 2 natioanl championships- Just got tired of repairing SS headers - Bolted the cast KE's on and never had an issue - they are not as sexy to look at as SS tube type but they have low initial cost and zero maintenance and do not have to be drained after every use -
ce of CMI, but how good are they?
I have called on them but they don't have any dyno test info.
We sell the best headers and mufflers offered in the marine industry - CMI Exhaust Headers have been on more National and World Championship Boats than all other exhaust systems combined!
KE makes a nice perfroming product. I doubt they perfrom as well as anyones headers system though.
Mercury Racing and Ilmor can't be wrong on their exhaust choice now can they?
Call us if we can help.
Kirk
Kirk
Charter Member #40
I'll bet if you knew what Merc was paying CMI for the pipes you would probably have a better understanding as to why they run them.
that su**S because it sounds like it's a great product and I can't use it,it looks like CMI or has anyone heard or used the new lightning platinum fresh water jacketed headers for the 496 offered by CP performance? They seem to be @ half pri
I had the KE Headers on my old boat, and I did pick up 2mph on a stock 502mpi. The only problem I had with them was I sucked up mud and the header melted on the inside top portion of the runner! Back to stock it went.
