What amp?
when in doubt..go bigger!! power doesnt blow speakers, distortion does, the bigger the amp the less the load, the less the distortion the better the sound.
Ginger or Mary Ann?
Not sure, but I think this one might do the job.
It's a 15,000 watt unit. That's if you don't mind the $21,000 price tag.
![Smilie](/forums/images/smilies/smile.gif)
with four spades on your subs they should be dual voice coil. This means you need to know if they are now 4 ohm or 8 ohm.? If they are 8 ohm you can wire them to go to 2 ohm for a better amp that is rated for 2 ohm. Please check your subs and if anything talk to someone at your local shop about coorect wiring...VERY IMPORTANT !!!
SUPER AIR
08-24-2006 06:47 AM
Secret F233
08-08-2002 05:37 PM
