Sources . grinding bits ... brass pipe plugs
Need good source for bits for Dremel and Air die grinder for Aluminum and Steel ....
Also need Brass pipe plugs Recessed Allen screw type ... I think there is a company that sells all kinds of metal and fittings ....the link shows up here from time to time .... thanks ....mike ...
Charter Member #139 /Moderator/Platinum Member
yes they are great
The wharehouse is close to my office so I can just pick things up there dont even have to wait for shipping
Big kids candy store
![Evil](/forums/images/smilies/evilB.gif)
Kept the Bullet and the condo and joined the cig 20 restoration club.
you can order the pipe plugs ... With or Without Sealant on the threads ..... Amazing
Brass Pipe Fittings and Pipe
2 products match your selections
Shape Plug
Plug Type Hex Socket Plug
Pipe Size 1/4"
Pipe to Pipe Connection NPTF x NPTF
Material Yellow Brass
Maximum Pressure (psi) 1200
High Pressure 1200
Specifications Met Not Rated
Sealant
Preapplied sealant on male threads | No Sealant
These 2 products match your selections
Sealant Each
Preapplied sealant on male threads 50785K213 $1.17
No Sealant 50785K113 1.00
Shape Plug
Pipe Size 1/4"
High Pressure 1200
Sealant
Sealant Each
