TRS vs Bravo 1 >
TRS vs Bravo 1
TRS vs Bravo 1
Old 02-16-2007, 03:49 PM
Default TRS vs Bravo 1
Does anyone know the "X" dimension conversion for the TRS drive is ? I know what the Bravo 1 is and want to do a comparison. Thanks
boatnuts is offline
Old 02-16-2007, 04:24 PM
cuda's Avatar
I have a Trs on a 22 Donzi. I can tell you that people in China duck when I motor by.
I have it backed in against my garage wall that I cut out, but I might be able to measure the bottom of the hull up to the outer transom assembly if that will help. Can't help you with the Bravo. My other two performance boats have a surface drive, and an Alpha drive.
cuda is offline
Old 02-16-2007, 05:50 PM
I have all measurements for the Bravo 1 but what I would like to know is bottom of boat to centerline of driveshaft thru the transom assembly on the upper gearcase and where the cavitation plate is relative to the bottom of the boat (distance above or below). I am also guessing yoy "V" bottom is rounded over. Thanks
boatnuts is offline
Old 02-16-2007, 06:27 PM
cuda's Avatar
A picture of the bottom. I can measure inside the engine compartment. I'd have to guess where the center of the shaft is, or again, the measurement to the bottom of the inside transom assembly.
Nice looking Hornet by the way.
Attached Thumbnails TRS vs Bravo 1-fc_3.jpg   TRS vs Bravo 1-3-23-005-small-.jpg
cuda is offline
Old 02-18-2007, 08:40 PM
Charter Member #232
Audiofn's Avatar
I can tell you that on my formula my drive shaft is 1 foot below the bottom of the boat. My caviation plate is even with the bottom. I am not sure what the centerline to centerline is on them....
Jon
Put your best foot forward!
Audiofn is offline
Old 02-19-2007, 07:25 AM
I think a TRS drive measurement from cavitation plate to the centerline of the input shaft in the upper gear case will tell me what I want to know?
boatnuts is offline
Old 02-19-2007, 02:58 PM
Lofty's Avatar
Why go from a good drive to a Bravo? If you're going to convert you should consider the Konrad. The TRS to Konrad conersion can be done in HOURS and requires no re-rigging.
Lofty is offline
Old 02-19-2007, 04:33 PM
Big Block Billy's Avatar
your much better with the konrads.they have a 1 1/4" prop shaft and the there alot wider on top
Big Block Billy is offline
Old 02-19-2007, 04:34 PM
with no rerigging
Old 02-20-2007, 10:05 AM
Konrads are great but big $$$. If you can do the Bravo conversion yourself its cheaper.
Pismo10 is offline
Quick Reply: TRS vs Bravo 1
