Trim tab pumps
If it's the style with the plastic resevoir I'm almost positive they're the same. The only thing that may be different is the valve body between the motor and the resevoir, which would affect the speed. There is an older style pump that has the metal resevoir (same dia. as the motor) and it's a lot slower, but again the only difference is the center valve body portion.
Offshoreonly Advertiser
It will work fine. Just remember on a drive the high pressure side is up, on a tab you want to reverse it. The blue wire runs the motor in the high pressure direction. I you do want to adjust it there are two relief valves visisble when you remove the resevoir. they have a lock nut on them, just loosen and turn.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
27 MAGNUM
Do It Yourself, Boating on a Budget
48
07-16-2008 11:09 PM
