Can I replace my Gen6 block w/ a Boe Tie?
Rob
![Question](/forums/images/icons/icon5.gif)
Will a 25534363 $1765.00. GM Bowtie block inerchange with my gen 6 502 block that came in my 500efi?
The 25534363 says its a one pc seal and the timing cover fits 5 and 6 covers.Says its machined for hyd roller and flat tappets.I really dont want to use the stock 10237292 when there's only 136.00 diff. I am planing on new short block assembly's for next winter,maybe more cubes too
Most of the engine guys use the gen 4 and change everything over to gen 4 stuff .I didnt really want to replace all the gen 6 stuff I already have.
or does Dart or World make one that will work w/ the gen 6 stuff.
Will this block work in place of my stock GM block?
Rob
http://store.summitracing.com/partde...t=nal-25534363
http://www.sdpc2000.com/catalog/387/...sman-Block.htm
http://www.gmpartsdirect.com/results...umber=25534363
http://www.gmpartsdirect.com/part_images/25534363.jpg
Rob
![Drink](/forums/images/smilies/drink.gif)
My understanding is that the major differences are wall thickness (Bowtie can go to 4.625 bore) , Blind head bolt holes and all of the previous MK4 and MK5 bowtie upgrades. However I have not used one yet so hopefully someone who has can chime in. I remember reading about someone using that block at 4.625 bore to make a 537" motor with the stock 4" stroke crank mark6 stuff to make a "reasonable cost" 540 ish engine. Not much room for rebuilds though.
Rob
The main thing I am asking if all the gen 6 stuff will bolt up to this Bowtie block?The gen 5-6 and bowtie's have Blind head bolt holes .
The blocks I have now are holding up fine, one is a little loose and figured I step up ci at the same time .
Will do H2Xmark
Registered User
Rob
or does anybody have a GOOD used Gen 6 502 block they want to sale?????????????
Rob
![EEK!](/forums/images/smilies/eek.gif)
