Blower Motors With Condensation >
Old 03-02-2007, 05:33 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Bob, get some t stats in there and get those engine temps up. I'll be helping a buddythis weekend that has the same setup as you. I'll pick his brain.
US1 Fountain is offline
Old 03-03-2007, 12:20 PM
Back4More's Avatar
Sorry If I kinda Hyjacked this thread...but the more heads we get together the better.
Back4More is offline
Old 03-03-2007, 03:29 PM
aex
aex's Avatar
I had an engine with a small amount of water migrating up a few head studs that were not properly sealed .
aex is offline
Old 03-04-2007, 05:35 PM
cariveau's Avatar
Do you by any chance have intercoolers? The symptom you are describing with water in the oil can also be caused by small leaks in an intercooler. After the boat is turned off, water can drip down into an open intake valve and seep past the rings into the oil. This can cause an unusual amount of milky oil in the valve covers. If the leak progresses, it can cause a hydrolock and break stuff. If you do have intercoolers you definatly want to do a leak test before you analyse much more.
cariveau is offline
Old 03-08-2007, 01:16 PM
Im having the same issue. No chiller lots of condensation on the blower and intake. water temp max has been 140* I dont have a oil temp yet but will. Noticed a oil color change to a tan not frothy just color. could the color be from the condensation or something else? was wondering if you solved you issue.
DAVEO is offline
Papache
09-23-2007 10:56 PM
dean51267
14
07-12-2006 10:39 PM
BOB ONEIL
15
11-18-2004 07:34 PM
Bad to the bone
12-11-2002 07:07 PM
birdog
9
07-03-2002 10:44 PM
Quick Reply: Blower Motors With Condensation
