Merc Bravo Drive Oil >
Old 03-19-2007, 10:34 AM
copiercat's Avatar
aerospacelubricants.com
copiercat is offline
Old 03-19-2007, 01:14 PM
Knot 4 Me's Avatar
I've used Amsoil in the past with good results. Never had a problem with the Merc HP.
Knot 4 Me is offline
Old 03-19-2007, 07:39 PM
Dave M's Avatar
Originally Posted by NightHawk
I would agree about the Merc HP. I've run the same Bravo 1 outdrive hard for 15 years on the stuff. Wake hopping, water skiing and racing. On my second factory engine but never had to touch the outdrive so far. I am sure this is common.
I run the Merc stuff too. 600+ hours, lots of flight time, no problems.
Dave M is offline
Old 03-19-2007, 08:30 PM
Originally Posted by Pwrbt33
I like to use the Mercury gear lube in the drives. I have tries Royal Purpleand have had gsome issues. Was it the oil? Who knows, went back to green and problems went away. Yet we run the Royal Purple racing 51 in some of the big motors we service and after its time to freshen up the engine builder said the inside looked great after 150 hours. 1150 Cobras. I use Mobil 1 and Valvoline Racing. Its all in what YOU think is a good oil. After all, Mercury oil lasted the warrenty period.
John S.
I had someone recommend using the same oil that is used in the # 6 drives to run it in a bravo drive when pushing over 600 hp. Thoughts?
Noise Pollution is offline
Old 03-19-2007, 10:21 PM
Charter Member #30
Scott's Avatar
One thing about the Merc green it does mix with water. This is a must in my opinion
I have Steps & Bubbles!
Scott is offline
Old 03-20-2007, 06:53 PM
Hydrocruiser's Avatar
Arrow
Good seals matter most.
Did you test your seals with a pressure/vacuum tester before adding in the new lube?
You should ya know.
Hydrocruiser is offline
Old 03-21-2007, 08:09 AM
Charter Member #30
Scott's Avatar
Hydro I may be reading into your post too much and your right but failure can happen at anytime. This is why I like a lube that will mix, it may save the day if you have a small leak before the next oil change.
Scott is offline
Old 03-21-2007, 08:49 AM
OldSchool's Avatar
I run the mercury green in my #6's and have run it in all of my previous Bravo's without any issues.
OldSchool is offline
Old 03-25-2007, 07:49 PM
What is the Merc Green? Is that Merc HP drive lube?
Pismo10 is offline
Old 03-25-2007, 07:50 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Yes
US1 Fountain is offline
bruin_d
06-05-2008 06:47 PM
jeff32
06-28-2006 08:48 AM
cloudmaster_321
18
05-01-2006 01:16 PM
rkeith01
5
04-04-2005 02:21 PM
Zanie
5
07-15-2004 07:13 AM
Quick Reply: Merc Bravo Drive Oil
