Spring Maintenance questions >
Old 05-15-2007, 02:13 PM
sleeper_dave's Avatar
I found fuel in the gear lube for the pump and replaced the fuel pump as a result. I don't know if they all do it or not, but fuel shouldn't be getting into that lube.
sleeper_dave is offline
Old 05-15-2007, 03:10 PM
to change the fuel pump lube do you just pull the fuel pump off or should pull the seawater pump,clean out all the old lube,replaced sea pump.i did mine this time last year but did suck sand at the end of the year.
awsomethunder is offline
Old 06-17-2007, 11:57 PM
c_deezy's Avatar
How do you go about loosening the belt for the raw water pump? Mine has v-belts and a tensioner, do you just loosen the nut on the tensioner until it slips off some? I felt around for an adjuster but couldn't get my big melon in front of the motor to get a better look
c_deezy is offline
Old 06-18-2007, 12:57 PM
There's a tensioner / idler pulley for that belt. There's what appears to be a nut on a stud holding the idler pulley on. The stud has a small hex at the end. loosen the nut and the idler will "back off" and relieve belt tension. To tighten it back up, put a nut on the end of hte stud and turn it, you'll see it tighten up on the belt. Get it to a good spot and tighten the nut up to hold it there.
cloudmaster_321
Do It Yourself, Boating on a Budget
8
07-13-2015 07:52 AM
Praetorian
12-26-2007 09:13 PM
Wild
2
04-06-2006 08:51 PM
Summer Heat
4
06-01-2005 06:45 PM
25 Eagle
11-20-2002 09:26 AM
Quick Reply: Spring Maintenance questions
