Oil In Distributor Cap
I'm getting oil up in my distributor,not a lot but after but 3 or 4 out you will see some oil in it. Its MSD are there any seals I can replace or do I have to buy a new distributor?
i believe there is a bushing / seal under the shaft which is turned bu the cam gear.
you ll have to remove the drift pin at the bottom of the distributor, which runs thru the gear. after that you ll be able to lift the shaft along with the reluctor out of the distributor housing and have a better view.
good luck.
good luck.
