Best Way To Clean Vinyl
#41
I bought some magic erasers to try. Asboslutely amazing. Told the wife the only time I remember something working that good was years ago on my first boat. I used "bleach white" the white wall tire cleaner. Lasted about another season then the vinyl fell apart. Not good on vinyl I guess
I'll be really interested in what you find out Downtown42. I'd love to keep using these suckers!
BT
BT
#43
2 years ago I cleaned some seats with bleach white (cut 50%with water) and a medium brush. Worked my AZZ off scrubbing everything. A couple days later I was told to try the Magic Erasers......you could see where I left off when I stopped 1/2 way through. Use small amounts of cleaner along with the Erasers, Spray 9 cut significantly or even Windex cleaners will help the Erasers clean even more quickly. I will use nothing else on my vinyl from now on!!!!!
#44
no doubt from the brothers, Magic is the cats a$$. I get nervous using a product for showers and ceramic tile and nothing mentions vinyl in the applications.
I just don't want my seats crumbling in 5 yrs.
#45
I knew it!!! Just got the reply back from Procter and G and the tech said continued use will eventually disolve the seats right down to the springs. Have fun dummies!!!
#46
you all fall for anything
ok here is reply....
Response (RightNow Administrator) - 04/11/2007 12:58 PM
It's good to hear from you.
The Mr. Clean Magic Eraser can be used on virtually all surfaces
found in your household, including: walls, floors, doors,
appliances, etc. It is ok for vinyl, but use light pressure. If
it has a shiny finish, it may remove the finish if scrubbing
hard.
I hope this helps!
Mr. Clean TeamCustomer - 04/10/2007 12:21 PM
For technical support re: Mr Clean Magic Eraser.
Alot of people use your product to clean vinyl seats on a boat.
Do you know of any harmful effects that could damage vinyl if
used over time? Thank you, Dave
I'll be in the Magic Club this weekend! tnks for the info.
hard.
I hope this helps!
