The ultimate "poor man's Drive"
what about the Sage #8? There is a Suberboat being built with this drive hooked to a turbine.
http://www.offshoreonly.com/forums/s...d.php?t=116625
Do you know how much the sage drive costs vs arneson 7 or merc 6?
Hey bud I hear you loud and clear! I dont want to go to that extreme plus you will scrub power and speed from the number 6 drive. We are waiting for one last try. We have gone through all brands none hold up what they claim. There maybe a new choice soon coming from Pfaff racing dont know when they will be introduced but they claim handling 1000hp motors. They are being tested on a 1500hp motor right now with great results. No promises here but if its true we are lined up with one as soon as possible.
point is there really is no substitution for it in a case like this. you can pick up a used 6 and gimbal for what your gonna spend on a maybe upgrade.
id look around
good luck
Charter Member #927
with all due there is really no scrub or power loss due to the 6 and tranny. as a matter of fact the same boat , same weight same power was faster with the 6's over bravos.(dry sump)
id look around
good luck
id look around
good luck
id look around
good luck
id look around
good luck
monstaaa you are telling it takes less power to turn a transmission and larger gears? I understand dry sump is more efficient than they wet #6 but I cant believe its easier than a bravo one.
